Revelprog-IS Hardware Test
farouq
Postby farouq » Mon Oct 29, 2018 7:00 pm
Hello
i am new owner of revelprog-is and in hardware test its ok But 5v Rail Is to Low
here is my Screen shoot
ps : i recived the programmer today is this normal thank u in advance
Re: Revelprog-IS Hardware Test
Postby ArT » Mon Oct 29, 2018 7:03 pm
Programmer is fine, don't worry :-) On some PC you will not have exact +5V but if you have >4.7V and all values on green then everything is fine.
farouq
Postby farouq » Mon Oct 29, 2018 7:05 pm
hello
thank u for your replay fastly i i appreciate your help.
best regards
Pityu
Been thanked: 7 times
Postby Pityu » Mon Nov 26, 2018 10:44 am
Hello ArT!
After programming in circuit with injection of 3V, I receive "device not find".
I think I need repairs. Can you help me repair it? Or should I send it to you.
Hardware test.jpg (153.38 KiB) Viewed 461295 times
Postby ArT » Mon Nov 26, 2018 12:36 pm
Hi Pityu,
2 buffers seems to be damaged, but all 4 should be replaced at once. They can be damaged e.g. when you make wrong connections and programming in circuit with external power supply (programmer can not limit external power supply and a high current from external power is going through these buffers).
There are 2 options:
1. you can send programmer to our service and we will repair it (shipping address the same as on invoice). Please include issue notes and shipping address for return.
2. you can try to replace it if you have such possibility, please check details below
Inside are 4 protection buffers SN74CB3Q3245PW in TSSOP-20 package. When you open programmer, you will see it without problems on the bottom side of PCB. When you replace it, please make hardware test again. All values should be green. There is a big chance that everything else is fine (they are protecting other circuit).
Example stores where you can find it:
https://eu.mouser.com/ProductDetail/Tex ... HeSJ3uo%3d
https://uk.farnell.com/texas-instrument ... CB3Q3245PW
https://www.tme.eu/en/details/sn74cb3q3 ... struments/
https://www.digikey.co.uk/product-detai ... -ND/864361
Please remember to replace all 4pcs (it is very important).
Hope it helps. If you need any more information please feel free to ask.
If you prefere to send it to us, please remember to include contact information.
Pityu
Postby Pityu » Wed Dec 12, 2018 9:47 am
Thank you ArT!
Everything are great again. :mrgreen: :mrgreen: :mrgreen:
Happy holidays !
Postby ArT » Wed Dec 12, 2018 12:15 pm
Awesome :mrgreen:
Thanks for info and happy holidays too!
TRX
Postby TRX » Wed Mar 29, 2023 5:24 pm
ArT wrote:Hi Pityu,
Hi.
In this case only 4 SN74CB3Q3245PW requires replacement or something else?
Postby ArT » Fri Mar 31, 2023 3:09 pm
Just replace buffers (all 4 at once) and it will work again.
