I found two bugs in Revelprog IS in interface for SFP modules, if is selected SFP from device database (SFP [A0] and SFP [A2] are alright:
- When writing the A2 or Page select area, a warning pops up that the checksum does not match. This is a nonsense report in this block. If one makes a mistake and clicks on the repair options, it will corrupt the code in the A2 block.
- In case the focus is set to the combobox "Area", attempting to work with the module using the hotkeys F5, F6,… will cause the corresponding script to run twice at the same time. If is focused another element in the form, the problem dosn't occur.
