Automatic Mode Production File bug
masterit
Postby masterit » Fri Jun 20, 2025 10:27 pm
i seem to be having an issue with this production file, it keeps failing and saying this device is not found in memory database, even though i'm able to select it in the regular device list.
Device is 93C66
i've attached the screenshot and the file below:
#REVELPROG-IS PRODUCTION FILE
#VER=1.9.0;
#DEVICE=93C66;
#VOLTAGE=5V;
#OPERATION=READ;
#FILE=Z:\IT\Date_Code_Tool\dump93C66.bin;
Re: Automatic Mode Production File bug
Postby ArT » Mon Jun 23, 2025 8:36 am
This functionality is still in beta. Please replace device database list from attachment (you need to unzip it). File location is in AppData Roaming files (type: %appdata%/revelprog-is in windows file explorer) and then below will work:
#DEVICE=93C66;
device_list.zip
(65.19 KiB) Downloaded 93 times
masterit
Postby masterit » Tue Jun 24, 2025 4:00 am
thank you that worked.
i had to also paste it into the AppData\Local\REVELPROG-IS folder and it worked then.
