93c46 Write fail and verification Issue
Posted: Sun Nov 30, 2025 2:46 pm
by Pops
Hi all, I am requesting help in programming a 93c46 eeprom! I am trying to make a backup of my chip, and i am able to read it with no issue and save it to a bin file. However, when i try to write the bin file to a new chip, it comes back with a write error and will not allow me to write,(verify) to the chip, it fails at the first address. So my first question is, does this programmer set the enable\disable registers on the chip, before writing? If not can you someone point me in the right direction or offer a solution to enable writing and verification.
Re: 93c46 Write fail and verification Issue
Posted: Mon Dec 01, 2025 12:52 pm
93xx chips do not have any locking registers which require to reset before write.
Do you programming it as 8-bit or 16-bit? Which 93C46 do you have exactly? (full signature / datasheet).
Posted: Mon Dec 01, 2025 3:30 pm
by Pops
The actual chip is a NMC93c46 EN. The datasheet I am using for this chip,is attached for reference. I have tried programming in 8bit and 16bit mode, but the same issue. The data sheet on page four states the chip has to have a write enable instruction to be sent before attempting a write!
Posted: Tue Dec 02, 2025 8:58 am
Please select EEPROM -> 93 series -> NMC -> NMC9346 and it will work.
Posted: Tue Dec 02, 2025 12:34 pm
by Pops
It worked,thank you so much for your help, i will not have to pull out what little of my hair remains now
