Fried Revelprog?
Posted: Wed Jan 14, 2026 7:58 pm
by itisdeadjim
I guess I just fried my device but I'd like to confirm that and maaaybe repair.
CS PIN of a probe just got contact to something 12V 3A ish. A little spark was emitted on the probe(d device) and the Revelprog disconnected :ugeek:
Unplug-Replug helped. At least the Revelprog is detected.
But when I want to dump some flash it starts dumping but the dump is always empty.
I can even dump air and without voltage ... I think that was not possible before.
It also seems that selecting speed does nothing. Always uses the maximum.
Anything I can do?
I did not yet take a look inside. There are 4 screws on the bottom with one being covered by a guarantee-sticker.
I guess guarantee does not apply here and it has been a few years since I bought it.
Is there something inside that the average user could fix? Or is something like SMD soldering at minimum required?
Re: Fried Revelprog?
Posted: Thu Jan 15, 2026 1:23 pm
Could you share me screenshot from hardware test, please? (available from the top menu).
If it's detected with USB it should be repairable.
Posted: Thu Jan 15, 2026 2:03 pm
by itisdeadjim
Values slightly vary with multiple measurements. But usually everything looks red.
Would a damaged protection circuit lead to empty dumps?
Question is if it is repairable by me ... (SMD)Soldering required?
Posted: Thu Jan 15, 2026 2:37 pm
Yes it can be repaired, but all protection buffers should be replaced. I'm sending you details via PM.
