Page 1 of 2
REVELPROG-IS for Linux
Posted: Fri Dec 14, 2018 1:28 pm
by kah
How can I use REVELPROG-IS from linux?
I do not see a linux version in the SW tab of
https://www.reveltronics.com/en/product ... b#softwareThanks,
Re: REVELPROG-IS for Linux
Posted: Sun Dec 16, 2018 12:48 pm
There is only Windows version, but REVELPROG-IS is working with libusb drivers so you can use any windows emulator on linux and it will work. It's working also on MAC. Only update process may not work, but programming and communication with programmer will work.
Posted: Fri Dec 21, 2018 1:33 pm
by kah
Hi Art,
Thank you for this.
I'm trying to run REVELPROG_IS.exe using mono, but I ran into this:
System.EntryPointNotFoundException: CreateCaret
at (wrapper managed-to-native) Be.Windows.Forms.NativeMethods:CreateCaret (intptr,intptr,int,int)
at Be.Windows.Forms.HexBox.CreateCaret () [0x0004c] in <d891967e8277410cbc3714881762f58d>:0
at Be.Windows.Forms.HexBox.OnGotFocus (System.EventArgs e) [0x00007] in <d891967e8277410cbc3714881762f58d>:0
at System.Windows.Forms.Control.WmSetFocus (System.Windows.Forms.Message& m) [0x00012] in <d5b72d15d4f7424c8a1538e3f19ec2e3>:0
at System.Windows.Forms.Control.WndProc (System.Windows.Forms.Message& m) [0x00217] in <d5b72d15d4f7424c8a1538e3f19ec2e3>:0
at System.Windows.Forms.Control+ControlWindowTarget.OnMessage (System.Windows.Forms.Message& m) [0x00000] in <d5b72d15d4f7424c8a1538e3f19ec2e3>:0
at System.Windows.Forms.Control+ControlNativeWindow.WndProc (System.Windows.Forms.Message& m) [0x0000b] in <d5b72d15d4f7424c8a1538e3f19ec2e3>:0
at System.Windows.Forms.NativeWindow.WndProc (System.IntPtr hWnd, System.Windows.Forms.Msg msg, System.IntPtr wParam, System.IntPtr lParam) [0x0008e] in <d5b72d15d4f7424c8a1538e3f19ec2e3>:0
It looks like this is a known problem and has been fixed in 2014:
https://github.com/Pkcs11Admin/Be.HexEditor/commit/c05c5df1358bf5427dd2fcec0e392a132cd69422https://bugs.debian.org/cgi-bin/bugreport.cgi?bug=767355What version of Be.Windows.Forms.HexBox.dll are you using?
Thank you
Posted: Sat Dec 22, 2018 9:29 am
Hmm no one had this problem before. I'll consult it and let you know.
Posted: Mon Jan 07, 2019 1:27 pm
by kah
Hi ArT,
I believe they were not using mono but probably a VM running windows...
From what I understand:
Version 1.6.1 has linux compatibility -
https://github.com/Pkcs11Admin/Be.HexEd ... NGELOG.txtHowever, this version is not released on sourceforge, last one there is 1.6.0 -
https://sourceforge.net/projects/hexbox/files/hexbox/I tried changing the .dll shipped with revelprog-is but both 1.6.0 and 1.6.1 has a missing method 'Be.Windows.Forms.HexBox.add_BufferLengthChanged' this is why I assumed Revelprog is not using the latest version of HexEditor
If this is the case, upgrading the dll to at least 1.6.0 on your side should allow me to replace the .dll with 1.6.1 and see if it is better
Regards,
Posted: Mon Jan 07, 2019 2:44 pm
It is not working because we are using custom made library (a lot of functional changes).
I prepared you files with updated functions. Please unzip and replace both files in installation folder (files are for v1.8):
https://www.dropbox.com/s/2ri15n34czbl3 ... e.zip?dl=0Please let me know about results.
Best Regards
Artur
Posted: Tue Jan 08, 2019 10:11 am
by kah
Thank you!
This is better. Now the GUI is loading correctly.
I have problem detecting the device now.
I'll check libusb is not being a derp.
USB: Device Not Found.
libpng warning: iCCP: known incorrect sRGB profile
libpng warning: iCCP: cHRM chunk does not match sRGB
Unhandled Exception:
System.NullReferenceException: Object reference not set to an instance of an object
at RevelprogIs.HID_USB.DisplayException (System.String moduleName, System.Exception e) [0x00035] in <8c38acd0e5a14018bf7887cbc38da647>:0
at RevelprogIs.HID_USB.FindTheHid () [0x0021e] in <8c38acd0e5a14018bf7887cbc38da647>:0
at RevelprogIs.HID_USB.Connect () [0x00002] in <8c38acd0e5a14018bf7887cbc38da647>:0
[ERROR] FATAL UNHANDLED EXCEPTION: System.NullReferenceException: Object reference not set to an instance of an object
Posted: Tue Jan 08, 2019 10:16 am
Hmm it seems that it is trying to detect REVELPROG in older version (up to 1.2.x) when it was using HID drivers (not libusb). It's trying to connect using HID if it can not detect programmer with default methods (libusb). I'll check it and try to prepare you software without support for older versions (without HID USD compatibility).
Posted: Tue Jan 08, 2019 10:50 am
Just checked it. I prepared you version which does not try to connect with HID devices (anyway it should not try use HID functions if it detect programmer with libusb). Please replace file and check it:
https://www.dropbox.com/s/xfh6qcz2f4uez ... S.zip?dl=0Please let me know.
Posted: Tue Jan 08, 2019 12:11 pm
by kah
There might be a problem with my install of libusb then. I'll see what I can do.
I see a "USB: Device Not Found." in console on startup
Now the GUI is stable but crashed when I clicked "Settings > Select Device"
at RevelprogIs.SQLiteDB.LoadData (System.String SQL) [0x0001f] in <c0c187fa157044869a4cafad829a4603>:0
at RevelprogIs.MemoryDB.LoadData (System.String SQL) [0x00000] in <c0c187fa157044869a4cafad829a4603>:0
at RevelprogIs.MemoryDB.GUI_DeviceListAddItems (System.Windows.Forms.ListBox deviceListBox, System.String sqlQuery) [0x00002] in <c0c187fa157044869a4cafad829a4603>:0
at RevelprogIs.MemoryDB.GUI_DeviceListShowTopLevel () [0x00019] in <c0c187fa157044869a4cafad829a4603>:0
at RevelprogIs.MemoryDB.MemoryDB_Load (System.Object sender, System.EventArgs e) [0x00039] in <c0c187fa157044869a4cafad829a4603>:0
at System.Windows.Forms.Form.OnLoad (System.EventArgs e) [0x00022] in <d5b72d15d4f7424c8a1538e3f19ec2e3>:0
at System.Windows.Forms.Form.OnLoadInternal (System.EventArgs e) [0x00029] in <d5b72d15d4f7424c8a1538e3f19ec2e3>:0
I'm not sure what DLL is missing.
Thank you for your time!
