SPI Read for laptop biops
laptopuri
Postby laptopuri » Fri Jun 14, 2019 10:58 pm
Hi from Romania
I have a HP Elitebook 8530 p bios with bios password unknown
I like not to dissamble the whole laptop to read ar write the bois . I like to use debug connector
Did any of us solve this ??
Regards , Vlad
Romania
laptopuri@yahoo.com
SPI Bios .JPG (93.59 KiB) Viewed 2185 times
debug port.JPG (104.75 KiB) Viewed 2185 times
hp 8530p=1=INVENTEC VB 1.0_6050A2096501 (1).pdf
(1.07 MiB) Downloaded 317 times
Has thanked: 18 times
Been thanked: 93 times
Re: SPI Read for laptop biops
Postby ArT » Mon Jun 17, 2019 2:20 pm
Yes you should connect to SPI lines as displayed in application and use external power supply (I can not see VCC line from flash memory on debug connector). When you connect external power supply (e.g. ac adapter from notebook) just wait 2-3 minutes before programming because it may be during bootloader init process and it will be conflict at spi bus.
Return to “REVELPROG-IS Technical Support”
