Eprom W25Q128JVSM and IS25LQ016
Posted: Tue Apr 07, 2020 12:20 am
I have a Revelprog recorder.
I can read the contents of the memorys with 1.8 volts are the memories: W25Q128JVSM and IS25LQ016, but when I have to record again in the memorys I have to change the voltage to 2.5v, even so, sometimes it doesn't. It's normal?
I would like to know if it is possible to read and write these memorys with fewer wires connected to the chip? That is, do I have to connect the 8 contacts?
On the other hand, when I test the hadware in the tools menu, it gives the following information. 'It's normal?
Thanks[img][/img]
Thanks[img][/img]
