QSFP Page Select is not working - timeout
Posted: Tue Mar 29, 2022 8:52 pm
I am able to read from QSFP modules using the A0h (256byte) mode but not when Page Select mode is used. Every time I try to read a page I get "PC TIMEOUT":
I also periodically get read timeouts when reading A0h.
Revelprog IS v1.8.5
Windows 11
Ryzen 3900X, X570 chipset
Various QSFP modules from Avago, Arista, KAIAM and Mellanox
The QSFP board is powered from a 2.1A USB charger. I have tried with the programmer hooked directly to ports on the motherboard that are USB 2.0, 3.0 and 3.1 but the results are always the same. I have only used the USB cables that came with the kit.
I have also noticed that when I try to write a byte the programmer will timeout on operation 2 or 3, but not consistently either one. It seems like a timing issue.
Any suggestions for other things to try?
12:22.150: Executing script started.
12:22.153: Setting hardware (I2C 3.2V SLOW)...success
12:22.333: Executing operation 1/2...success
12:22.443: Executing operation 2/2...fail
BSYO 0 ms , TOUT 1000 ms
INSTR: A0 80
DATA: NULL
12:24.143: Script execution cancelled.
12:24.153: PC TIMEOUT
Revelprog IS v1.8.5
Windows 11
