Updates v1.9.x for REVELPROG-IS (last update 2025-07-30)
Postby ArT » Wed Jun 08, 2022 1:05 pm
Update v1.9 for REVELPROG-IS is already available! :mrgreen: We would like to say THANK YOU for your feedback and suggestions - it is pleasure to make REVELPROG-IS better and better. There are few new features, improvements and supported devices. Update cost is... just kiding ;-) Your satisfaction is our number one priority, so as usual, update is free for all REVELPROG-IS users.
I. What's new in v1.9.0 ?
  • New supported devices
    Updated supported device list for FLASH, EEPROM and FRAM and:
    • added support for MultiStack FLASH SPI devices, e.g. GD25S512MD (DUAL DIE), W25M512JV (DUAL DIE), W25Q01JV (DUAL DIE), W25Q01NW (DUAL DIE 1.8V), W25Q02JV (QUAD DIE),
    • added beta support for KBC FLASH KB90xx chips e.g. KB9012, KB9016, KB9022, KB9026, KB9028
    • added support for W74Mxx Authentication Flash devices e.g. W74M64JV, W74M64JW (1.8V), W74M12JV, W74M12JW (1.8V), W74M25JV, W74M25JW (1.8V), W74M51JV, W74M51NW (1.8V), W74M01GV, W74M01GW (1.8V), W74M02KV, W74M02GV
    Please check latest supported device list on website.
  • W74M Authentication Flash
    Added W74Mxx Secure Authentication Flash tool for keys programming - please check more details and tutorial on other post: viewtopic.php?f=32&t=972
  • PreScript and PostScript operations
    Added pre- and post- scripts in memory database. There is possibility to execute additional custom script directly before or after memory operation (CTRL + ALT + SHIFT + S to activate option in memory database). It may be useful when you would like to change chip configuration directly before operation and restore configuration after operation, e.g.
    1. unlock device and disable quad spi (pre-script)
    2. write device (operation)
    3. enable quad spi and lock device (post-script)
  • Automatic mode with production file and command line
    New Automatic Mode tool (beta version) allows for programming devices based on production file. It is possible to run REVELPROG-IS application from command line with -productionFile "path.txt" parameter, so it will run and load production file on startup. In production file it is possible to configure: device name, operating voltage, operation type (READ, WRITE or ERASE), file path (for write or read operation), pre-script and post-script paths (for custom script tool).
    Video example how it works: https://youtu.be/69MQlU2r9k0
    Tutorial: viewtopic.php?f=32&t=913&p=3822
  • CustomScript Tool improvements
    • added #LeaveVppEnabled to custom script (leave VPP on after script execution) - it may be useful when you configure the device with custom script, but disconnecting power will cause reset and lost configuration
    • INSTR & DATA formatting - possibility to enter bytes in a row (without separation and without commas)
  • Hardware Toolbar
    New HW Toolbar (menu View -> HW overwrite) will alow to overwrite SCK speed or Imax current from quick toolbar
  • Fixed READ operation for SCK 10% and SCK 2% on some PCs due to USB timeout
  • Display current in mA for memory programming on status bar
  • Memory operation sounds (e.g. timeout error sound, verification success sound etc.)
  • Bug fixes and improvements for SFP/QSFP/XFP Transceivers:
    • XFP user password brute force bug fix (it writes 0x02 page before any write password operation - its necessary for some XFP because they are restoring default page in case of wrong password)
    • resetting flags (after brute force it was always time out during standard read)
    • Wait for end of operation for script executing before request next operation (for some xfp on some computers it were timeouts)
    • Extended maximum write delay to 255ms
II. Update
Update is optional and free. Programmer can be updated via USB from application. Please read update manual carefuly (Chapter 8) before update process.
At the moment you can download v1.9 installer from direct link:
III. Your feedback
IV. Previous updates
Missed previous updates? Please check 1.8.x changelog here
Pityu
Been thanked: 7 times
Re: Updates v1.9.x for REVELPROG-IS (last update 2022-06-14)
Postby Pityu » Wed Aug 10, 2022 4:45 pm
Hello ArT !
What can I say ? Love you for memory operation sounds !
Don't tell me I'm materialistic person :lol:
Re: Updates v1.9.x for REVELPROG-IS (last update 2023-05-08)
Postby ArT » Mon May 08, 2023 2:22 pm
New update v1.9.1 is already available. Firmware update is required. There are changes mainly for optical transveivers support. Added support for new OSFP, SFP-DD and QSFP-DD multi-lane transceivers adapter (you can read more about available adapters for SFP, XFP, QSFP, SFP-DD, QSFP-DD and OSFP here). Added support for new CMIS standard (please check supported standards here). Some customers also asked us about bruteforcing parssword in not default page - so we also added such feature. There also some minor changes, but generally if you do not need these improvements, you can stay with 1.9.0 which is still fine.
Please note that v1.9.1 requires programmer firmware v1.9.1 so if you have older firmware in REVLEPROG-IS you will need also update firmware to v1.9.1 (from application). If you do not need these changes you can stay with v1.9.0 software.
Firmware update - how it looks like video:
https://youtu.be/w3BxLNZBIso
Re: Updates v1.9.x for REVELPROG-IS (last update 2025-07-30)
Postby ArT » Wed Jul 30, 2025 2:07 pm
New update v1.9.2 is already available. Firmware update is required.
We added support for new devices and there are a lot of small changes in background which were implemented since last update.
  • new feature - added new option to custom script: #SAVETOFILE="C:/testfile.bin";
  • customscript and 1-wire few stability fixes + 1-wire write timeslot fix for some devices
  • customscript and i2c busy flag fix when busy time is zero
  • FileComparison 5k differences instead of 1k
  • Transceivers enter password fix and password location
  • new feature - Retry Loop during ICSP read and communication errors
  • Remember window maximized state in settings
  • Transceiver wrong selection warning for user
  • extended supported devices for Automatic Mode with production file
  • added devices specially on user requests, few examples: X24645, W25M161AV (16M-bit Serial NOR + 1G-bit Serial NAND), GD25LR512ME, W25M02GV (2x W25N0GV) + about 500 new FLASH IDs for READ ID (F10)
Please note: firmware update is required. Software v1.9.2 requires programmer firmware v1.9.2 so if you have older firmware in REVLEPROG-IS you will need also update firmware to v1.9.2 (from application). If you do not need these changes you can stay with v1.9.1 software.
Latest version v1.9.2 Setup: https://www.reveltronics.com/downloads/ ... _Setup.exe
Previous version v1.9.1 Setup: https://www.reveltronics.com/downloads/ ... _Setup.exe
Older versions: https://www.reveltronics.com/downloads/ ... h/archive/
