Page 2 of 4
Color and FONT changes please add
Posted: Thu Dec 17, 2015 12:14 am
by nunu78
Id like to see ability to change the FONT (size of the buffer) and color for each section, Id prefer a BOLD address its much thicker and easier to read and see data that way
should be user selectable on FONT size and color for each buffer window , data address, hex address and ASCII address
NO one wants to work in the plain built shady window environment, poorly visible text etccc.... people want to change color for their own personal preference of each window.
- color change.png (59.88 KiB) Viewed 12067 times
Switch between 8bit and 16 bit on screen
Posted: Sat Dec 19, 2015 12:30 am
by nunu78
Ones u read the chip. Have a button to switch between 8bit and 16bit buffer data
Button should be on screen visible all time below the menu screen. Like toggle 8 16. Maybe 32 if someone needs it? But 8 and 16 is a must
- 16bit.png (13.91 KiB) Viewed 12067 times
Ability to shift buffer data forward or back
Posted: Sat Dec 19, 2015 12:52 am
by nunu78
So with in the buffer after u read the chip - example say 93c56.
Add ability to move (shift) data forward or back WITHOUT adding lines or size to the buffer
So with in the selected EPROM. In this example 93c56. The content ones you read it. Be able to shift forward or back
Does that make sense ?
Some time some EPROMs has same data but it's off set by few address so to match compare must shift.
Copy paste flaw in program not working
Posted: Sat Dec 19, 2015 3:31 am
by nunu78
You have a copy paste flaw using external programs
If I copy a simple hex 10 in other program when I paste into your buffer it pastes about 4 addresses
You also can't copy buffer from your program and paste into other
Please fix
Copy from one hex paste into your program and vise versa
Currently not working
Copy paste buffer data
Address bar in buffer
Posted: Sun Dec 20, 2015 12:24 am
by nunu78
address bar in buffer 00 - 0F / 0-F see pic
- address bar.png (74.35 KiB) Viewed 12067 times
Marker Bar - to highlight and mark lines
Posted: Sun Dec 20, 2015 12:59 am
by nunu78
add option for MARKER BAR to highlight selected fields any color see pic
- marker bar.png (36.24 KiB) Viewed 12067 times
Re: Suggestions for next updates for REVELPROG-IS
Posted: Thu Feb 18, 2016 9:04 am
by nunu78
Soon it's been 6 months and not a single update ???? When is update coming with changes?????
Posted: Thu Feb 18, 2016 2:04 pm
We are focusing on supported device list not cosmetic changes. Currently we are working on 350160. We are also still waiting for 512MB flash spi samples from Winbond. Please be patient. If you need better hex editor features than I recommend you at the moment proffesional hex editor application - maybe WinHex?
ps. why are you using so many question marks?
Posted: Mon Feb 22, 2016 12:12 am
by nunu78
The interface needs to be pleasint easy user friendly and like able to each individual
Back in the 50s cars were only made in one color all black
No one would care about your win bond 512megs if the interface is difficult
Widen the spectrum don't just focus on PC memory.
Posted: Fri Feb 26, 2016 7:59 pm
