Data-logger in UTCOMP-PRO allows to record up to 10 parameters from sensors (e.g. boost pressure, EGT, AFR etc.) with maximum sampling 10sampl/s (10Hz) for each parameter. This functionality was already described here:
viewtopic.php?f=28&t=75. In incomming UTCOMP Android update (v0.1.3) we added possibility to read data logs with Android device. You can read more about UTCOMP Android app here:
viewtopic.php?f=21&t=322
- UTCOMP-Android-DataLogger-1.jpg (9.19 KiB) Viewed 11903 times
UTCOMP Android Data-Logger features:- download logs from UTCOMP-PRO (version >=3.7)
- import logs from external .csv file
- export logs to external .csv file
- data visualization on charts
Application will auto split one big file to few data-groups (ignition switch is a split point):
- UTCOMP-Android-DataLogger-2.jpg (14.37 KiB) Viewed 11903 times
Parameters visible on charts*:- timestamp/ignition time
- Afr/Lambda (ch #1 and ch #2)
- EGT (up to 6 channels)
- boost pressure
- oil pressure
- RPM
- vehicle speed
- engine coolant temperature
- oil temperature
- user temperatures (2 channels)
- inside/outside temperature
- battery voltage
- common-rail fuel pressure sensor voltage
- consumption (current/average)
*in UTCOMP-PRO there are 10 data banks so you can select up to 10 parameters with sampling 1Hz/5Hz/10Hz.
Example charts (full scale view):
- UTCOMP-Android-DataLogger-3.jpg (172.69 KiB) Viewed 11903 times
zoom + cursor:
- UTCOMP-Android-DataLogger-4.jpg (144.61 KiB) Viewed 11903 times
selected data with autoscaling and zoom:
- UTCOMP-Android-DataLogger-5.jpg (132.07 KiB) Viewed 11903 times
