Was also thinking about swapping boost for the fan symbol that a little bit looks like a spinning turbo.
Cool gadget this Reveltronics and very easy to install and setup.
// SPLASH 256x64 (size 0x2000 each)
#define SPI_FLASH_ADDR_LOGO256x64 0x0000 //size 0x2000 (0x0000 - 0x1FFF)
#define SPI_FLASH_ADDR_SPLASH256x64 0x2000 //size 0x2000 (0x2000 - 0x3FFF)
// ICONS 16x16 (size 0x80 each)
#define SPI_FLASH_ADDR_ICO_16x16_SIZE (16*16/2) // = 0x80 each
#define SPI_FLASH_ADDR_ICO_16x16_CELSJUS 0x4000
#define SPI_FLASH_ADDR_ICO_16x16_FARENHEIT 0x4080
#define SPI_FLASH_ADDR_ICO_16x16_DOLLAR 0x4100
#define SPI_FLASH_ADDR_ICO_16x16_FI 0x4180
#define SPI_FLASH_ADDR_ICO_16x16_FUELTANK 0x4200
#define SPI_FLASH_ADDR_ICO_16x16_G 0x4280
#define SPI_FLASH_ADDR_ICO_16x16_KM 0x4300
#define SPI_FLASH_ADDR_ICO_16x16_L 0x4380
#define SPI_FLASH_ADDR_ICO_16x16_ML 0x4400
#define SPI_FLASH_ADDR_ICO_16x16_OIL 0x4480
#define SPI_FLASH_ADDR_ICO_16x16_ROAD 0x4500
#define SPI_FLASH_ADDR_ICO_16x16_TIMER 0x4580
#define SPI_FLASH_ADDR_ICO_16x16_V 0x4600
#define SPI_FLASH_ADDR_ICO_16x16_ZL 0x4680
#define SPI_FLASH_ADDR_ICO_16x16_N 0x4700
#define SPI_FLASH_ADDR_ICO_16x16_R 0x4780
// ICONS 32x16 (size 0x100 each)
#define SPI_FLASH_ADDR_ICO_32x16_SIZE (32*16/2) // = 0x100 each
#define SPI_FLASH_ADDR_ICO_32x16_ACCU 0x5000
#define SPI_FLASH_ADDR_ICO_32x16_AFR 0x5100
#define SPI_FLASH_ADDR_ICO_32x16_BAR 0x5200
#define SPI_FLASH_ADDR_ICO_32x16_BIEG 0x5300
#define SPI_FLASH_ADDR_ICO_32x16_CAR 0x5400
#define SPI_FLASH_ADDR_ICO_32x16_CLOUD 0x5500
#define SPI_FLASH_ADDR_ICO_32x16_COST 0x5600
#define SPI_FLASH_ADDR_ICO_32x16_EGT 0x5700
#define SPI_FLASH_ADDR_ICO_32x16_FUELTANKPB 0x5800
#define SPI_FLASH_ADDR_ICO_32x16_FUELTANKON 0x5900
#define SPI_FLASH_ADDR_ICO_32x16_FUELTANKLPG 0x5A00
#define SPI_FLASH_ADDR_ICO_32x16_GEAR 0x5B00
#define SPI_FLASH_ADDR_ICO_32x16_GPH 0x5C00
#define SPI_FLASH_ADDR_ICO_32x16_KMH 0x5D00
#define SPI_FLASH_ADDR_ICO_32x16_KML 0x5E00
#define SPI_FLASH_ADDR_ICO_32x16_L100KM 0x5F00
#define SPI_FLASH_ADDR_ICO_32x16_LH 0x6000
#define SPI_FLASH_ADDR_ICO_32x16_MPG 0x6100
#define SPI_FLASH_ADDR_ICO_32x16_MPH 0x6200
#define SPI_FLASH_ADDR_ICO_32x16_OIL 0x6300
#define SPI_FLASH_ADDR_ICO_32x16_PSI 0x6400
#define SPI_FLASH_ADDR_ICO_32x16_RPM 0x6500
#define SPI_FLASH_ADDR_ICO_32x16_SNOW 0x6600
#define SPI_FLASH_ADDR_ICO_32x16_TEMP_ENGINE 0x6700
#define SPI_FLASH_ADDR_ICO_32x16_TEMP_U1 0x6800
#define SPI_FLASH_ADDR_ICO_32x16_TEMP_U2 0x6900
#define SPI_FLASH_ADDR_ICO_32x16_VAC 0x6A00
#define SPI_FLASH_ADDR_ICO_32x16_VAVG 0x6B00
#define SPI_FLASH_ADDR_ICO_32x16_VMAX 0x6C00
#define SPI_FLASH_ADDR_ICO_32x16_FAN 0x6D00
#define SPI_FLASH_ADDR_ICO_32x16_EGT1 0x6E00
#define SPI_FLASH_ADDR_ICO_32x16_EGT2 0x6F00
#define SPI_FLASH_ADDR_ICO_32x16_EGT3 0x7000
#define SPI_FLASH_ADDR_ICO_32x16_EGT4 0x7100
#define SPI_FLASH_ADDR_ICO_32x16_LAMBDA 0x7200
#define SPI_FLASH_ADDR_ICO_32x16_AFR2 0x7300
#define SPI_FLASH_ADDR_ICO_32x16_LAMBDA2 0x7400
#define SPI_FLASH_ADDR_ICO_32x16_EGT5 0x7500
#define SPI_FLASH_ADDR_ICO_32x16_EGT6 0x7600
// ICONS 32x32 (size 0x200 each)
#define SPI_FLASH_ADDR_ICO_32x32_SIZE (32*32/2) // 0x200 each
#define SPI_FLASH_ADDR_ICO_32x32_KMH 0x8000
#define SPI_FLASH_ADDR_ICO_32x32_KML 0x8200
#define SPI_FLASH_ADDR_ICO_32x32_L100KM 0x8400
#define SPI_FLASH_ADDR_ICO_32x32_LH 0x8600
#define SPI_FLASH_ADDR_ICO_32x32_N 0x8800
#define SPI_FLASH_ADDR_ICO_32x32_R 0x8A00
// ICONS64x64 (size 0x800 each)
#define SPI_FLASH_ADDR_ICO_64x64_SIZE (64*64/2) // 0x800 each
#define SPI_FLASH_ADDR_ICO_64x64_HEADLIGHTS 0xA000
#define SPI_FLASH_ADDR_ICO_64x64_WARNING 0xA800
#define SPI_FLASH_ADDR_ICO_64x64_SERVICE 0xB000
// ICONS128x20 (size 0xA00 each)
#define SPI_FLASH_ADDR_ICO_256x20_SIZE (256*20/2) // 0xA00 each
#define SPI_FLASH_ADDR_ICO_256x20_CONTROLLER 0xD000
Users browsing this forum: No registered users and 40 guests
