High value measured
Posted: Mon Mar 22, 2021 7:12 pm
I'm wondering how I can get this:
- My EGT are max on UTCOMP and VCDS which is Audi software
- I found a misconnected wire that fixed VCDS
- the UTCOMP value was at max ADC hence like a pull up
- some minutes later The UTCOMP reading was ok
Do you know why the fix was ok on Audi VCDS then I did not see the same fix on UTCOMP... I'm ondering how I can get the ADC saturation if the wire was the measured value... perhaps I have 2 or more issues.
hence
, how could I get a signal saturation on EGT-K board ?
hence
