I am trying to read a QSFP28/100G adapter (Intel) but in the output I am getting some weird characters (not vendor name, serial etc). Should I change anything? I chose QSFP from the menu. I tried to read SFP+ and it returned valid data (vendor name etc). The software version is the 1.9.1.
QSFP28 Read
Re: QSFP28 Read
Could you check in your QSFP datasheet how is it coded? It should be SFF-8436 or SFF-8636 which is valid for QSFP transceivers but I think that your QSFP transceived is compilant with SFF-8472 which is valid for SFP/SFP+. It happens rarely but when it happen, in such case it should be read/write as SFP not QSFP.
PS. you can read more about MSA standards here: https://forum.reveltronics.com/viewtopi ... =32&t=1017
Re: QSFP28 Read
Thanks for the reply.
The datasheet says the it is following the spec SFF-8636
https://www.intel.com/content/www/us/en ... brief.html
I got some results when I set the area to 128B Page Mapping. Is this right?
Also, I am trying to start password tool but I am getting the error "device TIMEOUT". Any help on this?
Re: QSFP28 Read
It based on SFF-8636, and check you power supply if returns error.
I have several the same modules, and test all are fine.
Re: QSFP28 Read
Sorry for the late response. How I can check the power supply?
@thankfly are you selecting QSFP type? Also are you getting results with the read operation with the default settings? (256)
@ArT How can I send you the dumps? Directly or I can post them here?
Re: QSFP28 Read
I attach two .bin. One with default read settings (256) and one with page select (128)
- 20230623_113849_EEPROM_QSFP.zip
- (426 Bytes) Downloaded 943 times
Re: QSFP28 Read
The page select file (128B) looks fine, but A0 area file (256B) looks corrupted, in second half only 2 first bytes are read correctly. Please select "BP" checkbox - any difference?
Re: QSFP28 Read
Yes, using BP the read is correct. What is the case? What is the function of BP?
Also, when I am trying to 'bruteforce' the password I am getting device timeout error.
