Dear
In the menu of software doesn´t exist this model of DS2430A, only appear the conection with 8 pin.
Could you help me in order to connect reveltronic IS with this TSOC?
in the schematic of software describe connection as: 4 GND, 5 DATA and 8 VDD, but TSOC configuration from datasheet of Maxim doesn´t have VDD pin
Many thanks in advance
Mike1
read and write DS2403A TSOC
Re: read and write DS2403A TSOC
I checked this datasheet:
https://www.analog.com/media/en/technic ... S2430A.pdf
and TSOC package has only data and ground pins.
Pin 1 is ground, Pin 2 is Data - just connect only these 2 pins and it will work.
Pin 1 of memory to Pin 4 of programmer
Pin 2 of memory to Pin 5 of programmer
