Logging carburettor Harley
Hooter
Post by Hooter »
Hi I want to log carburettor type Landspeed Harleys. I semi crew for the owners and am an advanced performance efi dyno tuner, but have never logged a carby type engine except on my dyno with the usual AFR and bolt on Knock sensor box to headphones...
On the salt, the rider does not have time to look or digest a digital dash, so data logging is obvious..
I would like dual wideband o2, maybe dual EGT's duel cylinder head knock sensors, and dual cylinder head temps, and if possible log ignition advance, which is running a Dynafire adjustable ignition module with 4 different curves, which can be changed globally by rotating base ignition plate similar to rotating distributor....
Also need rpm and others that I know are standard features..
Do you think this is achievable with your Utcomp system
Any help much appreciated
