Hi, I’m currently having problems with the calibration of my Prosport controller with my UTCOMP PRO.
The UTCOMP v3.5+ calculator opens as a locked document, so I can’t use it for my controller.
Could somebody please help me with the calculation for my values?
And how can I use these values to display them as Lambda?
I only have the values from this document on page 3/3:
https://www.merx-tuning.de/media/9f/cd/ ... nzeige.pdf
Thanks for the help and greetings from Germany
-Dominik
Prosport AFR/Lambda Controller
Re: Prosport AFR/Lambda Controller
for MAP and pressures you can use simple calculator from UTCOMP app available in settings -> advanced -> pressure -> calculator and use AFR instead of bar.
