I want to install a wideband controller.
On the Manual i see there is connection to a wideband controller.
Is there wideband controller you recommend to install? zeitronix, innovate with BOSCH LSU 4.9 sensor etc.......
Calibration needed?
wideband controller
- Been thanked: 176 times
Re: wideband controller
UTCOMP supports all 0-5V controllers and you should connect it to any AdcX input. You will need also to know its output to scale it in utcomp's settings: http://www.reveltronics.com/forum/viewt ... ?f=28&t=58
thanks for reply
The output data i have for the controller is 0 Volt = 7.35 AFR and 5 Volt = 22.39 AFR
Is that enough to introduce in your excel calibration?
thanks for reply
