As you can see, in UTCOMP-PRO currently digital output on pin B7 (DigOutUser) is not used- it will change soon
"UTCOMP-PRO CONTROLLER" title icon may be changed by user - please take a look custom icons and graphics tutorial
DigOutUser specification (pin B7 in UTCOMP-PRO):
- +5V in ON mode
- HiZ (disconnected) in OFF mode
- current load <50mA (max 100mA*)
Input signal source:
- temperature inside the vehicle
- outside temperature
- engine or cooling temperature
- oil temperature (e.g. for engine or gearbox)
- user temperature
- vehicle speed
- above upper (HI) threshold
- below lower (LO) threshold
- above LO and below HI thresholds
- below LO and above HI thresholds
- manual mode
- possibility to set hysteresis
- possibility to set minimum battery voltage for regulation (ability to disable regulation when battery voltage drops below selected value, e.g. regulation is enabled only when engine is running)
- relay control switch based on internal temperature (e.g. for air condition control - climatronic)
- relay control switch based on engine/cooling temperature (e.g. for cooler control, glow plugs control etc.)
- enabling buzzer or LED for selected vehicle speed (e.g. speed limit warning)
- relay control switch based on vehicle speed (e.g. door auto-lock mechanism)
Is relay always required?
If current load on output is above 100mA (0,1A) or there is need to control external device with different voltage levels (e.g. 12V) than monostable relay is required. You will not need relay if you want to control low power devices, e.g. buzzer or small LED.
Relay selection guide:
- monostable relay with 5V coil
- recommended coil resistance above 100 ohms
- relay switching power below 250mW (<0,25W)
- example relays: AZ850-5
