I2C SPI Custom Script Programming [TUTORIAL & EXAMPLES]
laptopuri
Re: I2C SPI Custom Script Programming [TUTORIAL & EXAMPLES]
Postby laptopuri » Tue Jan 08, 2019 11:02 pm
We need a toool for reading and writing JTAG on varios laptops . Can revelprog read and write on this bus ?
Regards , Vlad
jtag .PNG (85 KiB) Viewed 2959 times
Has thanked: 20 times
Been thanked: 95 times
Postby ArT » Wed Jan 09, 2019 2:57 pm
Hi Vlad, unfortunately REVELPROG-IS does not support JTAG interface at the moment.
Postby ArT » Tue Feb 12, 2019 12:26 pm
Since v1.8.1 REVELPROG-IS will be supporting 1-wire interface in custom script tool. Here is example for DS2436 battery chip: viewtopic.php?f=22&t=436&p=2143
ovidiugabrielstan
Postby ovidiugabrielstan » Fri Jul 31, 2020 10:21 am
Hello, can you please help me with some details about the following problem: I would like to use revelprog-is programmer together with some other microcontroller programmers, using a .bat file. This would allow me to 'automate' the programming process of a custom made board. I am using the revelprog-is programmer to flash a binary file for a FPGA device, memory type ISSI IS25LP064, which works great using GUI.
Is it possible to use revelprog-is programmer from the command line? Something like C:\path\revelprog-is.exe <memory_type> <operation_type> <binary_file>
For example: C:\path\revelprog-is.exe IS25LP064 -Write C:\myBinFile.bin
If such a feature exists, can you please direct me to a manual/description? I can't use the scripting tool, as it would be a lot easier to just use the GUI for that matter.
If this feature isn't available, can you please plan it for a future release? It would make the revelprog-is programmer a must for many others I believe.
Thank you and have a nice day,
Ovidiu Gabriel
Postby ArT » Fri Jul 31, 2020 12:17 pm
Unfortunately REVELPROG-IS application is GUI based. We have in plans command line interface but it needs to write new app from scratch to make it GUI independent. We have it in plans but I can not promise any date at the moment so at the moment I recommend to find other solution. Please check also this subject viewtopic.php?f=22&t=415&start=10 last @bigendian post - he prepared command line software for his own (for linux) and it's working with few FLASH devices
