Switching Signal with no wire connected
Inzan3
Post by Inzan3 »
Hello, i have a problem again. On ADC2 of my UTComp Pro the reading switches between 0 and 5V but the wire isnt connected :-( any Ideas for that?
Re: Switching Signal with no wire connected
It is normal with not connected signal (input is floating). Just connect signal and you will have proper reading.
Inzan3
Post by Inzan3 »
No difference, connected the wire to 0V (Ground) still switching between 0 and 5V. Same Problem with NTC Temp Signal from Engine Coolant
Please share your utcomp settings file - I'll check it and test it tomorrow (I'm out of office now).
And which input is it?
Inzan3
Post by Inzan3 »
I will copy it tomorrow, i think its ADC 2 but i have testet to load factory settings nothing changed
You have to configure input to get activate it. Please share you settings file and I'll check if problem is with configuration or with module.
Inzan3
Post by Inzan3 »
Here is my settings File :-)
UTCOMP_v3-4_settings_2017-7-22_184035.rar
(3.61 KiB) Downloaded 687 times
When you connect Adc2 (A9) to A12 (GND) than in readings tab do you have 0V on Adc2 input?
Then when you connect A9 to A6 do you have around 5V on input?
Inzan3
Post by Inzan3 »
[youtube]https://youtu.be/CWsoBmCElvM[/youtube]
Nothing changed when on A12,A6 or not connected still switching between 0,00 and 5,18
It seems that you are right and something is wrong with module.
What about other inputs? If other inputs are fine than this one input is damaged, if other inputs are the same that it seems that analog amplifier is damaged. Have you tried to connect more than 5,5volt signals to 0-5V inputs? Please send us unit (module only) for tests (and service), I'm sending you details on PM.
