Hi guys.
Installed the reveltronics UTCOMP PRO today and are using these sensors...
Boost:
https://www.reveltronics.com/en/shop/60 ... -5v-detail
Fuel pressure:
Oil pressure:
Intake air temperature:
https://www.reveltronics.com/en/shop/59 ... ter-detail
EGT:
https://www.reveltronics.com/en/shop/62 ... ype-detail
For the pressure sensor I'm using a digital 5v supply from the UTCOMP PRO. All sensors have the same ground.
Everyrhing seems to work.
EXCEPT for the fuel pressure. Don't know what's wrong really. If the sensor it self is bad or what.
In the software there is not alot of pressure sensor options really.
Give me a few tips please.
Fuel pressure sensor problem [solved]
Re: Sensor problems
Hello
For fuel pressure you should set 2 options in settings:
1. Settings -> Configuration -> and select "Fuel pressure sensor" for appropriate AdcX input
2. Settings -> Advanced -> Pressure -> enter fuel pressure sensor parameters: a = 2.59 and b = -1,29 (b with minus!)
Save sttings to UTCOMP (CTRL + S)
And how about with these settings? What results do you have?
