Updates v1.8.x for REVELPROG-IS (last update 2020-01-27)
Has thanked: 20 times
Been thanked: 95 times
Postby ArT » Wed Oct 24, 2018 12:44 pm
Update v1.8 for REVELPROG-IS is ready to download! We would like to say THANK YOU for all your suggestions. Your satisfaction is our priority, so as usual, update is free for all REVELPROG-IS users :)
I. What's new in v1.8.0 ?
  • FLASH NAND SPI
    This is huge change. Now REVELPROG-IS supports Serial NAND Flash devices. It supports 1Gb and 2Gb devices at the moment:
    • read/erase/write operations for standard area and spare bytes
    • ECC checking enable/disable feature
    • Blocks Checker tool (finding faulty blocks)
    • Read Device ID
    Please take a look here for more information and Serial NAND FLASH device list.
  • 1Gb and 2Gb FLASH SPI NOR support
    Added support for 1Gb and 2Gb FLASH SPI 25xx devices. A lot of optimization in code. Less RAM consumption, faster buffer operations, faster checksum calculations, faster diff checker tool. Some of these changes were already implemented in v1.7.1 as a beta feature.
  • Updated memory database
    We are observing that nowadays more and more manufacturers are extending offer with low voltage chips (e.g. 1.8V). The memory database has been updated with latest FLASH and F-RAM devices. Please check current device support list.
  • Other changes and fixes
    - improved self diagnostic test,
    - fixed write without erase for some devices,
    - added 2% SCK mode for FLASH SPI,
    - and more not relevant changes..
II. Update
Update is optional and free. Programmer can be updated via USB from application. Please read update manual carefuly (Chapter 7) before update process.
At the moment you can download v1.8 installer from direct link:
hhttps://www.reveltronics.com/downloads ... _Setup.exe
III. Your feedback
IV. Previous updates
Missed previous update? Please check 1.7.1 changelog (Aug 2018) version here (2nd post)
Re: Update v1.8 for REVELPROG-IS
Postby ArT » Mon Apr 15, 2019 1:13 pm
Update v1.8.1 is released. It will be available via autoupdater soon, at the moment you can download it here:
Changelog:
- added 1-wire protocol to custom script programming
- added DS2436 battery chip
- added XMC FLASH NOR SPI 1.8V devices (e.g. XM25QU64A. XM25QU128C, XM25QU256C etc.)
- added MX25U12890F, AT25DN512C, AT25DN011
- added 24U17
- added LE25FS406
- added M24M01-DR and M24M02-DR
- fixed 5p08c3 in search engine
- added GD25WD 1.8V/3.3V series (e.g. GD25WD80C, GD25WD40C, …)
- added GD25LB 1.8V series (e.g. GD25LB64C, GD25LB128D, GD25LB256D, …)
- added GD25B 3.3V series (e.g. GD25B64C, GD25B127D, GD25B256D, …)
- added GD25D 3.3V series (e.g. GD25D40D)
Re: Updates v1.8.x for REVELPROG-IS (last update 2020-01-27)
Postby ArT » Mon Jan 27, 2020 2:13 pm
Update v1.8.2 is released. It will be available via autoupdater soon, at the moment you can download it here:
Changelog:
- added QSFP/QSFP+ and XFP transceivers support with hardware adapter (new QSFP SFP XFP Adapter will be available in offer soon),
- added password tool for SFP/QSFP/XFP transceivers (and search password tool with brute force method) - please check new Chapter 7 in updated manual and forum posts/tutorials: viewforum.php?f=31,
- added FLASH SPI: ATXPxx series (EcoXiP) 1.8V devices (ATXP32, ATXP64, ATXP128),
- added FLASH SPI: AT25FF321A (1.8/3.3V), AT25FF161A (1.8/3.3V, AT25FF081A (1.8/3.3V), AT25FF041A (1.8/3.3V), IS25LE512M (3V), MT25QL01G (3.3V), MT25QL02G (3.3V), W25Q512JV (3V), W25Q01JV (3V),
- added FRAM SPI: 2Mb CY15V102Q (1.8V), 4Mb CY15V104Q (1.8V), 8Mb CY15B108Q (3.3V), 8Mb CY15V108Q (1.8V), 2Mb MR45V200A (3.3V)
- added FLASH NAND SPI (up to 4Gb): 1Gb TC58CYG0S3HRAIG (1.8V), 1Gb TC58CVG0S3HRAIG (3.3V), 2Gb TC58CYG1S3HRAIG (1.8V), 2Gb TC58CVG1S3HRAIG (3.3V), 4Gb MT29F4G01ADAGD (3.3V), 4Gb MT29F4G01ABAFD (3.3V), 4Gb MT29F4G01ABBFD (1.8V), 4Gb TC58CYG2S0HRAIG (1.8V), 4Gb TC58CVG2S0HRAIG (3.3V), 1Gb W25N01GV (3.3V), 1Gb W25N01GW (3.3V), 1Gb W25N01JW (1.8V), 1Gb W25N02JW (1.8V), 1Gb W25N02KV (1.8V)
- increased F-RAM >1Mbit SPI devices read/write speed,
- fixed bug with Read ID when first bytes are dummy
FIRMWARE UPDATE is required! You can skip this update if you do not need these improvements.
Hope you will like it! :)
