How can I use REVELPROG-IS from linux?
I do not see a linux version in the SW tab of https://www.reveltronics.com/en/product ... b#software
Thanks,
REVELPROG-IS for Linux
Re: REVELPROG-IS for Linux
There is only Windows version, but REVELPROG-IS is working with libusb drivers so you can use any windows emulator on linux and it will work. It's working also on MAC. Only update process may not work, but programming and communication with programmer will work.
Hi Art,
Thank you for this.
I'm trying to run REVELPROG_IS.exe using mono, but I ran into this:
https://github.com/Pkcs11Admin/Be.HexEd ... 132cd69422
https://bugs.debian.org/cgi-bin/bugrepo ... bug=767355
What version of Be.Windows.Forms.HexBox.dll are you using?
Thank you
Thank you for this.
It looks like this is a known problem and has been fixed in 2014:System.EntryPointNotFoundException: CreateCaret
at (wrapper managed-to-native) Be.Windows.Forms.NativeMethods:CreateCaret (intptr,intptr,int,int)
at Be.Windows.Forms.HexBox.CreateCaret () [0x0004c] in <d891967e8277410cbc3714881762f58d>:0
at Be.Windows.Forms.HexBox.OnGotFocus (System.EventArgs e) [0x00007] in <d891967e8277410cbc3714881762f58d>:0
at System.Windows.Forms.Control.WmSetFocus (System.Windows.Forms.Message& m) [0x00012] in <d5b72d15d4f7424c8a1538e3f19ec2e3>:0
at System.Windows.Forms.Control.WndProc (System.Windows.Forms.Message& m) [0x00217] in <d5b72d15d4f7424c8a1538e3f19ec2e3>:0
at System.Windows.Forms.Control+ControlWindowTarget.OnMessage (System.Windows.Forms.Message& m) [0x00000] in <d5b72d15d4f7424c8a1538e3f19ec2e3>:0
at System.Windows.Forms.Control+ControlNativeWindow.WndProc (System.Windows.Forms.Message& m) [0x0000b] in <d5b72d15d4f7424c8a1538e3f19ec2e3>:0
at System.Windows.Forms.NativeWindow.WndProc (System.IntPtr hWnd, System.Windows.Forms.Msg msg, System.IntPtr wParam, System.IntPtr lParam) [0x0008e] in <d5b72d15d4f7424c8a1538e3f19ec2e3>:0
Thank you
Hi ArT,
I believe they were not using mono but probably a VM running windows...
From what I understand:
Version 1.6.1 has linux compatibility - https://github.com/Pkcs11Admin/Be.HexEd ... NGELOG.txt
However, this version is not released on sourceforge, last one there is 1.6.0 - https://sourceforge.net/projects/hexbox/files/hexbox/
I tried changing the .dll shipped with revelprog-is but both 1.6.0 and 1.6.1 has a missing method 'Be.Windows.Forms.HexBox.add_BufferLengthChanged' this is why I assumed Revelprog is not using the latest version of HexEditor
If this is the case, upgrading the dll to at least 1.6.0 on your side should allow me to replace the .dll with 1.6.1 and see if it is better
Regards,
Regards,
It is not working because we are using custom made library (a lot of functional changes).
I prepared you files with updated functions. Please unzip and replace both files in installation folder (files are for v1.8):
https://www.dropbox.com/s/2ri15n34czbl3 ... e.zip?dl=0
Please let me know about results.
Best Regards
Artur
Best Regards
Artur
Thank you!
This is better. Now the GUI is loading correctly.
I have problem detecting the device now.
I'll check libusb is not being a derp.
USB: Device Not Found.
libpng warning: iCCP: known incorrect sRGB profile
libpng warning: iCCP: cHRM chunk does not match sRGB
Unhandled Exception:
System.NullReferenceException: Object reference not set to an instance of an object
at RevelprogIs.HID_USB.DisplayException (System.String moduleName, System.Exception e) [0x00035] in <8c38acd0e5a14018bf7887cbc38da647>:0
at RevelprogIs.HID_USB.FindTheHid () [0x0021e] in <8c38acd0e5a14018bf7887cbc38da647>:0
at RevelprogIs.HID_USB.Connect () [0x00002] in <8c38acd0e5a14018bf7887cbc38da647>:0
[ERROR] FATAL UNHANDLED EXCEPTION: System.NullReferenceException: Object reference not set to an instance of an object
Hmm it seems that it is trying to detect REVELPROG in older version (up to 1.2.x) when it was using HID drivers (not libusb). It's trying to connect using HID if it can not detect programmer with default methods (libusb). I'll check it and try to prepare you software without support for older versions (without HID USD compatibility).
Just checked it. I prepared you version which does not try to connect with HID devices (anyway it should not try use HID functions if it detect programmer with libusb). Please replace file and check it:
https://www.dropbox.com/s/xfh6qcz2f4uez ... S.zip?dl=0
Please let me know.
Please let me know.
There might be a problem with my install of libusb then. I'll see what I can do.
I see a "USB: Device Not Found." in console on startup
Now the GUI is stable but crashed when I clicked "Settings > Select Device"
Thank you for your time!
I'm not sure what DLL is missing.System.NullReferenceException: Object reference not set to an instance of an object
at RevelprogIs.SQLiteDB.LoadData (System.String SQL) [0x0001f] in <c0c187fa157044869a4cafad829a4603>:0
at RevelprogIs.MemoryDB.LoadData (System.String SQL) [0x00000] in <c0c187fa157044869a4cafad829a4603>:0
at RevelprogIs.MemoryDB.GUI_DeviceListAddItems (System.Windows.Forms.ListBox deviceListBox, System.String sqlQuery) [0x00002] in <c0c187fa157044869a4cafad829a4603>:0
at RevelprogIs.MemoryDB.GUI_DeviceListShowTopLevel () [0x00019] in <c0c187fa157044869a4cafad829a4603>:0
at RevelprogIs.MemoryDB.MemoryDB_Load (System.Object sender, System.EventArgs e) [0x00039] in <c0c187fa157044869a4cafad829a4603>:0
at System.Windows.Forms.Form.OnLoad (System.EventArgs e) [0x00022] in <d5b72d15d4f7424c8a1538e3f19ec2e3>:0
at System.Windows.Forms.Form.OnLoadInternal (System.EventArgs e) [0x00029] in <d5b72d15d4f7424c8a1538e3f19ec2e3>:0
