Wire size?
Timoes
Has thanked: 4 times
Wire size?
Post by Timoes »
What type of wire size should be selected for the following sensors:
  • Oil and fuel pressure sensor 150 PSI 10 BAR
  • Oil and water temperature sensor NTC analogue
  • Temperature sensor for UTCOMP
  • EGT-K LMP (connection to UTCOMP)
  • EGT-K LMP (connection to EGT-K probe)
  • Cable to the original wiring harness or control unit of the car
With best regards, Timoes
Re: Wire size?
Hi Timoes, please take a look at page 11: https://www.reveltronics.com/downloads/ ... manual.pdf
Timoes
Re: Wire size?
Post by Timoes »
Thank you very much. I should have read the manual again before I post here.
