Question about power supply
Mtime
Postby Mtime » Tue Apr 02, 2019 12:14 pm
Hey guys,
So I wanted to read a motherboard yesterday but everytime I tried it gave me a warning about s
Power protection or some sort of it.
Even if I made the volt voltage lower or even disabled it. It kept giving that message.
And is there a beginner tutorial to learn everything about reading chips
Thanks a lot in advance
Has thanked: 15 times
Been thanked: 78 times
Re: Question about power supply
Postby ArT » Tue Apr 02, 2019 7:53 pm
Are you sure that connections are fine?
Does programmer is still functional (does it pass hardware test?)
In Chapter 5 in manual there are a lot of information about in circuit programming. But if you are beginner I recommend you to programm in socket or adapter, because ICSP requires a lot of experience from user and it may be not safe in many cases (in socket is 100% safe).
Mtime
Postby Mtime » Wed Apr 03, 2019 12:44 pm
Thanks alot, i have bypass the power supply problem now
But the other problem now is that the test clip im using for reading a EEPROM is not working. The software is setup perfect. But whatever i try, i can not read my chip from the motherboard using a test clip 8 pins. Anybody have a solution?
Pityu
Postby Pityu » Sat Jun 08, 2019 3:57 pm
What type of chip do you try to read/write and what is the name of motherboard?
