Bosch MAP Sensor NTC
snaxxi
Postby snaxxi » Sun Jun 16, 2019 9:51 pm
i have an UTCOMP-PRO and wanted to connect my MAP sensor. I'm using a 400 kPa Bosch Sensor with 4 Pins (Part No. 0 281 002 576). Boost signal works fine but i also want to use the NTC resistor for intake temperature.
I'm not sure if i have to connect it to AdcX (0-5V) or 0 AdcVccX (0-5V, +5V PULL-UP) since the sensor is already powered with 5V since i just split the cable (one from car harness and one for UTCOMP). Also i'm not sure about the configuration and set the following based on bosch documents:
url: http://360.haubits.net/VolvoRacing.se/Sensors.pdf
Resistance: 2,5kO
Temperature: 293,15K (20°C)
With this configuration and connection to AdcX (0-5V) i get ridiculous values.
I hope you guys can help me out.
Has thanked: 18 times
Been thanked: 93 times
Re: Bosch MAP Sensor NTC
Postby ArT » Mon Jun 17, 2019 2:26 pm
You should connect to AdcX but you will need to get voltage (NOT resistance) table, so you will need to connect with diagnostic tool and make table temperature/voltage and scale with this table
snaxxi
Postby snaxxi » Mon Jun 17, 2019 4:20 pm
Thank's for your answer. So the connection is right at least.
So i have to get the voltage/temperature table and calculate the needed values for UTCOMP configuration from there?
Can you provide me a link how to calculate those values?
Postby ArT » Tue Jun 18, 2019 9:37 am
You have ready to use excel in this thread:
viewtopic.php?f=28&t=58 (use NTC(U) sheet).
Please feel free to ask if you will have any further questions :)
