Suggestions for next updates for REVELPROG-IS
REVELPROG-IS update notes, news and general discussion about REVELPROG-IS and device/memory programming.
nunu78
Color and FONT changes please add
Post by nunu78 »
Id like to see ability to change the FONT (size of the buffer) and color for each section, Id prefer a BOLD address its much thicker and easier to read and see data that way
should be user selectable on FONT size and color for each buffer window , data address, hex address and ASCII address
NO one wants to work in the plain built shady window environment, poorly visible text etccc.... people want to change color for their own personal preference of each window.
color change.png (59.88 KiB) Viewed 86899 times
nunu78
Switch between 8bit and 16 bit on screen
Post by nunu78 »
Ones u read the chip. Have a button to switch between 8bit and 16bit buffer data
Button should be on screen visible all time below the menu screen. Like toggle 8 16. Maybe 32 if someone needs it? But 8 and 16 is a must
nunu78
Ability to shift buffer data forward or back
Post by nunu78 »
So with in the buffer after u read the chip - example say 93c56.
Add ability to move (shift) data forward or back WITHOUT adding lines or size to the buffer
So with in the selected EPROM. In this example 93c56. The content ones you read it. Be able to shift forward or back
Does that make sense ?
Some time some EPROMs has same data but it's off set by few address so to match compare must shift.
nunu78
Copy paste flaw in program not working
Post by nunu78 »
You have a copy paste flaw using external programs
If I copy a simple hex 10 in other program when I paste into your buffer it pastes about 4 addresses
You also can't copy buffer from your program and paste into other
Please fix
Copy from one hex paste into your program and vise versa
Currently not working
Copy paste buffer data
nunu78
Address bar in buffer
Post by nunu78 »
address bar in buffer 00 - 0F / 0-F see pic
address bar.png (74.35 KiB) Viewed 86899 times
nunu78
Marker Bar - to highlight and mark lines
Post by nunu78 »
add option for MARKER BAR to highlight selected fields any color see pic
marker bar.png (36.24 KiB) Viewed 86899 times
nunu78
Re: Suggestions for next updates for REVELPROG-IS
Post by nunu78 »
Soon it's been 6 months and not a single update ???? When is update coming with changes?????
We are focusing on supported device list not cosmetic changes. Currently we are working on 350160. We are also still waiting for 512MB flash spi samples from Winbond. Please be patient. If you need better hex editor features than I recommend you at the moment proffesional hex editor application - maybe WinHex?
ps. why are you using so many question marks?
nunu78
Post by nunu78 »
The interface needs to be pleasint easy user friendly and like able to each individual
Back in the 50s cars were only made in one color all black
No one would care about your win bond 512megs if the interface is difficult
Widen the spectrum don't just focus on PC memory.
Yes you are right, but I think that capabilities and supported device list is more important than integrated pretty hex editor (there is always possibility to download professional hex editor as standalone application). Please understand that we are not giant company and we have to have priorities. Thank you for your suggestions. We appreciate it and we do our best. We want to implement some of your ideas in incoming update, here is a small proof that we are working on it and we listen users:
Fill option:
Apperance customization:
Patterns (customizable templates):
