its in planin
disi77
its in planin
Postby disi77 » Thu Sep 19, 2019 11:54 am
Its in planing a ext powersupply? Now i cant use the programmer when i mobile. No Dash eeprom read.....
Has thanked: 17 times
Been thanked: 89 times
Re: its in planin
Postby ArT » Tue Sep 24, 2019 12:05 pm
All updates for REVELPROG-IS are software updates - for high current application you need to use external power supply or try tricks with lowering voltage for operation (so other circuit will be in sleep mode and drain lower current) - you can read more about it in Chapter 5 in manual.
disi77
Re: its in planin
Postby disi77 » Fri Oct 11, 2019 11:49 am
ok. But its not planning a Powersuply build in ? I thinks looks like Galep ?
Re: its in planin
Postby ArT » Mon Oct 14, 2019 7:35 pm
REVELPROG-IS has built in power supply only from USB (by default 100mA, max 200mA current).
You can use any external power supply and you will get as high current as you need in very simple way.
