In order to swap icons in UTCOMP-PRO do following steps:
1. Connect UTCOMP-PRO and run UTCOMP app
2. Switch to "Settings" tab
3. Click "CTRL + ALT + H" buttons. "HARDWARE" tab will be displayed in settings.
4. Enter "#FLASH" authorisation code.
5. Advanced options will be displayed.
Each graphic and icon has own address in FLASH memory which starts "0x..."
In bottom window ("Graphics addresses in FLASH memory") you can find all address codes for all graphics .
Few examples below.
Battery icon (32x16 pix) can be found at address 0x5000:
FLASH_ADDR_ICO_32x16_ACCU 0x5000Code: Select all
FLASH_ADDR_ICO_32x16_CLOUD 0x5500Code: Select all
FLASH_ADDR_ICO_32x32_KMH 0x8000In order to upload your custom graphic you should:
1. Load bitmap icon. It's important to load icon which exacly the same resolution as icon to be replaced.
2. Enter icon address in FLASH memory (when you enter incorrect address you will overwrite different icon!)
3. Click "UPLOAD(bmp)" button.
In this way you can prepare your own custom icon set, download it as single file and share to others. Just click "Download FLASH (bin image)" and next click save icon to save file on your computer. Below you can find default flash file with all oryginal graphics - just in case if you overwrite default icons and want to restore it:
edit: updated graphics image file for v3.2 version: edit: updated graphics image file for v3.4 version:
