There is new version of calculator for scaling (calibration) analog sensors:
UTCOMP v3.5+ calculator: https://1drv.ms/x/s!AsGCGuEkUvVGsDN4JGd ... L?e=vRmTca
UTCOMP v3.4 (and older) calculator: https://www.dropbox.com/s/cjpidy5gf90hhe2/NTC.xls?dl=0
Sheet includes calculators for:
- NTC analog temperature sensors,
- voltage (linear) sensors (e.g. for MAP sensor, AFR controller etc.)
- resistance (linear) sensors (e.g. for pressure 0-10 bar sensor)
Thanks to calibration process, there is possibility to connect almost any analog sensor to UTCOMP achieving high accuracy of readings. Maybe it looks complicated at the beginning, but trust me, it's NOT. I'll help you if you have any issues.
For analog temperature sensors (NTC) two constants are needed:
R25 and Beta (three constants for older versions:
A, t, t0).
For analog linear sensors (voltage or resistance) you will need two constants (
a and
b).
In order to calibrate sensors connected to
AdcX input, you will need only data table with voltage<->readings.
AdcVccX input, you will need data table with resistance<->readings or voltage<->readings (if you connect sensor you can read voltage at sensor in utcomp app). If you have only resistance data that you will need also two constants: (1) value of pull-up resistor in UTCOMP (Rpullup) - it's equal to 1000 Ohm (+/- 0,1%) for UTCOMP-3 and UTCOMP-PRO; (2) value of voltage reference for analog circuit (VREF) - typical values are 5.0, 5.2 or 5.4 volts - you can read VREF in "Readings" tab in UTCOMP app (since version 3.1, in older versions it was always 5.0 volts). Every UTCOMP-PRO is stock calibrated to achieve best accuracy, so everyone can have slightly different VREF value.
Please feel free to ask in this thread if you have any questions about scaling and calibration analog sensors.
