I just tried updating from v1.7.0 to v1.8.2. The app updates without issue but I cannot find a way to successfully update the programmer firmware. The Zadig installer does not detect the programmer; if I look explicitly for all devices then it is in the list, but the install process aborts after 5 minutes. Running RevelProg within Windows 10, within VMWare Fusion (USB2.0 only) on a Macbook Pro.
Many thanks,
Matt
firmware upate failing updating to v1.8.2?
MattPadden
- Been thanked: 1 time
Re: firmware upate failing updating to v1.8.2?
Hi Matt, for update mode (DFU) is different driver and it will not work on VMware, please update it directly on Windows (you can use other PC) and then it will work with latest software on vmware.
MattPadden
