hi,
i have a problem to modify the splash screen.
I have a good format for my user splash screen, but if i want to choose sample splash screen, it don't work too...
Do you have an idea why it don't work??
This is default user bitmap. You can also change it in UTCOMP windows app: settings > preferences -> splash screen, next you should select user graphic 256x64 and load BMP file from external file and next you need to remember to check checkbox to save new bitmap with settings (otherwise it will not upload with saving settings)
ArT wrote:This is default user bitmap. You can also change it in UTCOMP windows app: settings > preferences -> splash screen, next you should select user graphic 256x64 and load BMP file from external file and next you need to remember to check checkbox to save new bitmap with settings (otherwise it will not upload with saving settings)
Yes i know, i do it but it don't work.
I only can change it if i modify the default user bitmap... I don't understand
