Pistou
- Been thanked: 3 times
Post
by Pistou »
I have a camshaft on my car where the output signal is a square waveform.
Does your input accept and calculate the right value based on this signal ?
Thank you
Post
by ArT »
Yes it should work
You need to connect it to RPM input and later in settings scale it (number of pulses per revolution)
Pistou
Post
by Pistou »
Ok thanks I'm gonna try, the DigInUser input is also a high impedance right ?
Post
by ArT »
Nope, DigInUser is for digital signal only, impedance is about 300kOhm.
Only AdcX are high impedance.
Pistou
Post
by Pistou »
So it might disturb the camshaft sensor?
Post
by ArT »
300k is still quite high, it should not, tested many times
Pistou
Post
by Pistou »
Thank you Art !
