DS2434 is 1-wire device with 16-bit unique ID, 2-byte battery cycle counter, A/D converter for battery temperature monitoring and 32 bytes eeprom for user data (total memory area is 160 bytes divided to 5 pages, but not all bytes are used).
Connection requires 3 wires:
- ground (pin 4 in programmer),
- data line (pin 5 in programmer),
- vdd (pin 8 in programmer)
This is how I connected it with REVELPROG-IS socket but you can also try to programm it in external circuit. Below are ready to use scripts for REVELPROG-IS.
You can read more about Custom Scripts Programming here: https://forum.reveltronics.com/viewtopic.php?f=22&t=280
DS2434 Read EEPROM (5 pages, 32 bytes per page = 160 bytes total*)
// DS2434 READ (5 pages, each 32 bytes = 160 bytes total)
#SCRIPT HEADER;
SCRIPT:v1.8.5;
#HARDWARE SETTINGS;
HW:1-WIRE,5.0V,SLOW;
// PAGE 1 read (24 EEPROM bytes + 8 dummy bytes)
#OPERATION;
SW:0,0,0,0,0,0,0,0,0,500;
INSTR:71; // COPY NV1 to SP1
#OPERATION;
SW:0,0,1,31,0,0,0,0,0,500;
INSTR:11, 00; // READ SCRATCHPAD + SP1 ADDR
// PAGE 2 read (8 EEPROM bytes + 24 dummy bytes)
#OPERATION;
INSTR:77; // COPY NV2 to SP2
#OPERATION;
INSTR:11, 20; // READ SCRATCHPAD + SP2 ADDR
// PAGE 3 read (32 SRAM bytes)
#OPERATION;
INSTR:7A; // COPY SRAM to SP3
#OPERATION;
INSTR:11, 40; // READ SCRATCHPAD + ADDR
// PAGE 4 read
#OPERATION;
INSTR:B2, 60; // READ REGISTERS + REG. START. ADDR
// PAGE 5 read
#OPERATION;
INSTR:B2, 80; // READ REGISTERS + REG. START. ADDR
DS2434 Read 16-bit unique ID
//DS2434 Read ID Register (16-bit)
#SCRIPT HEADER;
SCRIPT:v1.8.5;
#HARDWARE SETTINGS;
// Read ID Register
#OPERATION;
SW:0,0,1,1,0,0,0,0,0,500;
- data from buffer (since v1.8.5 only)
//DS2434 WRITE EEPROM (using current data in buffer)
#SCRIPT HEADER;
SCRIPT:v1.8.5;
#HARDWARE SETTINGS;
// Unlock NV1
#OPERATION;
SW:0,0,0,0,0,0,0,10,0,500;
INSTR:44; // Unlock NV1
// PAGE1 Write EEPROM (24 bytes)
#OPERATION;
SW:1,23,0,0,0,0,0,0,0,500;
INSTR:17, 00; // WRITE SCRATCHPAD + SP1 address
DATA: BUFFER, 0;
#OPERATION;
INSTR:22; // Copy SP1 to NV1
// PAGE2 Write EEPROM (8 bytes)
#OPERATION;
SW:1,7,0,0,0,0,0,0,0,500;
INSTR:17, 20; // WRITE SCRATCHPAD + SP2 address
DATA: BUFFER, 20;
#OPERATION;
INSTR:25; // Copy SP2 to NV2
// PAGE3 Write RAM & SRAM (32 bytes)
// please note: it will be lost when battery disconnected
#OPERATION;
SW:1,31,0,0,0,0,0,0,0,500;
INSTR:17, 40; // WRITE SCRATCHPAD + SP3 address
DATA: BUFFER, 40;
#OPERATION;
INSTR:28; // Copy SP3 to SRAM
//DS2434 Reset Battery Cycle Counter
#SCRIPT HEADER;
SCRIPT:v1.8.5;
#HARDWARE SETTINGS;
// Reset cycle counter
#OPERATION;
INSTR:B8; // Reset Battery Cycle Counter
//DS2434 Increment Battery Cycle Counter
#SCRIPT HEADER;
SCRIPT:v1.8.5;
#HARDWARE SETTINGS;
// Increment cycle counter
#OPERATION;
INSTR:B5; // Increment Battery Cycle Counter
// Read cycle counter
#OPERATION;
INSTR:B2, 82; // READ Cycle counter register
//DS2434 Read Battery Cycle Counter
#SCRIPT HEADER;
SCRIPT:v1.8.5;
#HARDWARE SETTINGS;
#OPERATION;
DS2434 Read Battery Temperature (with A/D conversion at first step)
//DS2434 Read Battery Temperature
#SCRIPT HEADER;
SCRIPT:v1.8.5;
#HARDWARE SETTINGS;
// Start A/D conversion for temperature
#OPERATION;
INSTR:D2; // Convert T
// Dummy - wait for temperature conversion (max 1000ms)
#OPERATION;
SW:0,0,0,0,250,250,250,250,0,1500;
INSTR:B2, 62; // READ Status Register
// Read Temperature
#OPERATION;
INSTR:B2, 60; // READ Temperature Register
