UTCOMP-3 and UTCOMP-PRO
Martins SDI
Re: UTCOMP-3 and UTCOMP-PRO
Post by Martins SDI »
This new version can be connected to the original fuel line of the car to make the fuel measurement?
My car doesn't have 0-5V signal in fuel line. It works only with resistance.
All analog inputs are 0-5V (there is also 0-30V input in pro version) so will you need voltage signal. Fuel level is measured from resistance sensor, in most cases sensor is powered from +5V or +12V so you can measure voltage drop directly on it and it will work.
Locked
