Hi
the boost pressure shows incorrectly, I have a boost pressure of 1.4-1.6 bar, but the display shows 2.3 bar. how do i set it right?
thanks
- Been thanked: 176 times
Re: boost pressure shows incorrectly
I guess you are using external MAP sensor. You need to provide sensor data in UTCOMP settings (settings -> advanced -> pressures -> boost). If you do not know scaling data I can help you scale it. Do you have possibility to check boost pressure via obd2? We will need 2 measurements points pressure/voltage.
Hi
at 0.52v at Ut-comp, the opcom shows me 102 Kpa, so I think the ambient pressure must be subtracted, when idling I have negative boost pressure, the display shows that -0.9 bar. Only when I have boost pressure does it show me too much.
please let me know your "a" and "b" parameters in settings for boost sensor and please fill below table, I'll check your scaling:
pressure from opcom (kpA) | voltage on UTCOMP input
100kPa = .... volts
200kPa = ... volts
it does not have to be exactly 100kPa or 200kPa
100kPa = .... volts
200kPa = ... volts
