Sensors to allow fitting to 1970's VW camper van.
terryrow
Postby terryrow » Sun Jun 30, 2019 9:42 pm
I am thinking of fitting utcomp to 1970's VW camper van which naturally has no built in sensors. Most seem to be easily set up, with the exception of finding fuel flow which is sensitive enough for very low flow rates, eg 0.08 liters/minute. Fuel pump is mechanical with just a flow to the carburetter. It would be possible to loop fuel flow back to the tank but concerned about continuous pump activity. Anyone have any suggestions, methods or sensors?
Re: Sensors to allow fitting to 1970's VW camper van.
Postby ArT » Tue Jul 02, 2019 10:20 am
Minimum 0,5l/h, please check example pdf from attachment. At page 13-17 are connection diagrams for diesel engines.
You can try to conctact with this company maybe they will have more sensitive flow meters at the moment. They are from Bulgaria as I know.
catalog_Mechatronics_new_en_300.pdf
(1.25 MiB) Downloaded 804 times
Inst_Direct_Delta ver 1.pdf
(930.05 KiB) Downloaded 851 times
DArtagnon
Postby DArtagnon » Sat Oct 19, 2019 7:32 pm
This might work: http://enginemeter.com/site/index.php?o ... Itemid=479
From supplier:
You can supply this sensor from +4.5 to +24V.
The current consumption is about 10mA.
There is an internal 10kOhm pull up resistor on the output (pulse signal).
Buy here: https://www.ebay.com/itm/Fuel-Flow-Sens ... 2592002652
