Update v3.8 for UTCOMP-3 and UTCOMP-PRO
Has thanked: 58 times
Postby ArT » Mon Apr 20, 2020 2:43 pm
UTCOMP-3 and UTCOMP-PRO had already many updates which added improvements or new features (e.g. Android app for all modules). New v3.8 update is adding few improvements and bug fixes, please check details below.
Changelog v3.8 for UTCOMP-3 and UTCOMP-PRO
  • added support for UTCOMP Android v0.1.5 please take a look at android features in UTCOMP Android app on forum
  • speed measurement up to 999 km/h or mph (before it was 255 kmh or mph)
  • added settings for analog inputs averaging (it can be customized to make measurements faster or more stable, e.g. different averaging for temperature sensors which should be slow and stable or Boost/AFR/EGT which should be very fast) - you will find these settings in UTCOMP Settings -> Advanced -> ADC
  • added manual data-logger (logging can be enabled or disabled from menu) with current memory state - long press SW1 to activate this menu (manual data-logger should be enabled first in settings -> advanced -> datalogger)
  • increased RPM speed (x5) for high resolution RPM signals (minimum 30 impulses per wheel rotation)
  • added possibility to activate "boat mode" where fuel consumption measurements (and all related measurements) are in l/h or gph which are independent from speed and distance (by default it's l/100km or mpg which are distance related)
  • fixed EGT in Farentheits, Boost pressure refreshing in PSI and other small fixes.
Your feedback
I would like to use this oportunity to encoruage you to write a review about UTCOMP-3 or UTCOMP-PRO on product site, UTCOMP Facebook profile, UTCOMP Android app (Google Play) or in any place on the internet 8-) If you have suggestions for next updates please share it on forum in dedicated topic. Your opinion is important to us! Thank you! :)
Update v3.7
Update v3.6
Update v3.5
Update v3.4
Update v3.3
Update v3.2
FrankKoba
Re: Update v3.8 for UTCOMP-3 and UTCOMP-PRO
Postby FrankKoba » Tue May 19, 2020 10:00 am
Hi Artur,
I would like to update my UTCOMP-PRO from 3.7 to 3.8. Because it takes over a year for me to find a proper setup of all the parameters, I am looking for a secure way to update without loosing the parameter setup for UTCOMP. I saved parameter config files to my PC, but I noticed that the 3.8 PC software does not accept to read the saved parameter files made by 3.7.
Can you offer a description and/or procedure for taking over the 3.7 setup to 3.8? (I apologize if I am wrong and the update does not affect the current setup in the UTCOMP).
Your feedback is very welcome.
best regards
Frank
Postby ArT » Tue May 19, 2020 12:55 pm
Hi Frank, it shows error but it loads data. Only few things may be imported not properly. Please send me on PM your v3.7 settings file and I'll check it on v3.8
FrankKoba
Postby FrankKoba » Fri May 22, 2020 11:45 am
Hi Arthur,
that was good news - in the meantime I managed to visually compare the same parameter file in both the 3.7 and 3.8 version and my configuration looks the same in both.
So I will do the update now. Thanks a lot for this info and your offer!
Postby ArT » Fri May 22, 2020 12:13 pm
Just one notice. If "boat mode" will be activated after import (consumption in l/h or mph only) then you can deactivate it by:
a) restoring default settings and set everything from hand, or
b) in hidden boat setting - by activating HARDWARE tab (CTRL + ALT + H in settings) and enter #BOAT in field
Kaldek
Has thanked: 7 times
Been thanked: 5 times
Postby Kaldek » Fri Aug 07, 2020 11:30 am
ArT wrote:Just one notice. If "boat mode" will be activated after import (consumption in l/h or mph only) then you can deactivate it
Hi Artur, mine did this as well. Any idea why the upgrade defaulted to this?
Postby ArT » Fri Aug 07, 2020 4:25 pm
You need to restore default settings after update, if you do not restore default settings or if you import not compatible settings (from older version) then behavior is unpredictable
Pistou
Been thanked: 3 times
Postby Pistou » Tue Dec 15, 2020 10:06 pm
Hi, how is deleted the data log? Automatically?
Postby ArT » Wed Dec 16, 2020 7:31 am
Yes oldest data are overwritten with fresh data.
Pistou
Postby Pistou » Sat Dec 19, 2020 10:14 pm
Hi Artur, can we erase the utcomp flash by ourself to ensure we have the 18 minutes at max sampling ? Thx
Users browsing this forum: No registered users and 23 guests
