Programmer is not connected (V1.9.0)
woko
Postby woko » Tue Jun 20, 2023 11:04 am
Dear Revelprog Team,
my Revelprog-IS Software updated itself to V1.9.0 and I have Problems with the driver installation.
I tried under Help/install driver and install driver (zadig) but both fail (Driver installation cancelled by user)
The device is found in the Zadig Tool.
Thx for your help!
Wolfgang
Re: Programmer is not connected (V1.9.0)
Postby ArT » Tue Jun 20, 2023 1:05 pm
Hi Wolfgang,
Which version did you have before update? I'm asking because since v1.3 driver is the same.
woko
Postby woko » Wed Jun 21, 2023 8:25 am
I don't know. Did not use it for a long time.
Postby ArT » Wed Jun 21, 2023 9:32 am
If you had v1.2.x or older - you need to uninstall manually driver from device manager (red led should blink) and then install it as described in manual.
If you had v1.3.x or newer - it should work with the same driver.
Does RED LED:
1. is off
2. is blinking
3. is on?
1 means that programmer has not power supply or is damaged
2 means that programmer is working but driver is not installed correctly
3 means that programmer is working and driver is installed correctly
woko
Postby woko » Wed Jun 21, 2023 9:54 am
The red LED is slowly blinking.
I try installing the driver, it looks exactly like seen in the Youtube Video.
But after I press "install Driver" it hangs (not responding). Yesterday, a Message box with "Driver installation cancelled by user" came up.
Postby ArT » Wed Jun 21, 2023 1:32 pm
I think that's system issue, something external is blocking driver installation. Please check it on other PC, it will work.
woko
Postby woko » Fri Nov 03, 2023 11:32 am
had the same problem again, I think its because the driver is not signed
woko
Postby woko » Fri Nov 03, 2023 12:20 pm
it worked now, by disabling temporary the sign check. You should consider singing the driver in the future.
https://www.driversupport.com/knowledge ... ut%20issue
Postby ArT » Fri Nov 03, 2023 3:18 pm
Zadig installs signed driver so I worry that issue has to be in different place
XAMCTBO
Postby XAMCTBO » Thu May 02, 2024 3:04 pm
hi, I will nick this post.
having same issue
cannnot install drivers just says.
SMTicroelectronics STTub30 ready to use
REVELTRONICS Libusb0 libusb-win32 devices 06-28-2015 install failed
win 10 x64
yes i installing 64 version
did try manually - same thing.
Users browsing this forum: No registered users and 38 guests
