Your description says "car electronics & automotive (reprogramming modules, radio-code, immobilizers, gps navigations, mileage correction and other modules with serial EEPROM and/or FLASH memories),"
I would like to see a calculator implemented into this program that will allow users to write their own changes made in the buffer and store as a calculator for future use.
So lets say we read eeprom from 95040
in the buffer the changes I make manually by replacing the characters - I would like that data to change color so I know what I have replaced and where and then Right click and ADD TO CALCULATOR, - next time I read the same eeprom instead of doing the changes manually again I would open my saved calculator and click apply and it would make the changes.
THAT WOULD BE AWESOME
stream line the work flow
see pic
- changes.png (55.82 KiB) Viewed 76254 times
