Datalog
Donkerewolk
Datalog
Postby Donkerewolk » Wed May 31, 2017 8:23 pm
Hey
I have some questions about the dataloging of the utcomp pro.
Would it be possible to datalog the parameters 2 or 4 times a second?
What happens if te memory is full? Does it overwrite the old data?
We want to use the utcomp as as simple race data loger/dysplay.
Thank you in advance.
Re: Datalog
Postby ArT » Wed May 31, 2017 9:56 pm
In current version (v3.4) it is 1 sample per second. We are considering to make in update option for 5 samples per second for analog values, but I can not promise at this time because we have not tested it yet.
When memory is full it overwrites oldest data.
Donkerewolk
Re: Datalog
Postby Donkerewolk » Thu Jun 01, 2017 10:17 am
Thank you for your response, it would be great if you can realise that.
Grz
Re: Datalog
Postby ArT » Tue Jun 06, 2017 1:09 pm
Just to let you know - 5 samples per second will be available for: speed, egt (all channels), afr (both channels), boost, oil pressure and fuel pressure. This function is already implemented and it is during tests so it should be available with v3.5 update.
