Tank Level Sensor
Inzan3
Tank Level Sensor
Postby Inzan3 » Fri Jun 02, 2017 8:11 pm
Hello, i have a little problem. My Tank Level Sensor is a Pull-down type ( measure resistance to Ground) and UTComp needs Pull-up to 5V. It isnt possible to use it as Pull-Up what can i do?
Re: Tank Level Sensor
Postby ArT » Sat Jun 03, 2017 11:08 am
It's fine because you are measuring voltage level directly, so you will have e.g. ~5V on tank empty and ~0V on tank full and it will work too.
Inzan3
Postby Inzan3 » Sat Jun 03, 2017 7:25 pm
So the Tank gauge supplies the 5V?
Postby ArT » Sat Jun 03, 2017 8:32 pm
In most cases voltage is in range of 0-5V. In older cars it may be 0-12V. I'm talking about stock sensors connected to AdcX input (if you want to connect additional sensor than it should be connected to AdcVccX and it should be minimum 1k ohm resistance range)
