Oiltemperatur Digits
SEMAC
Postby SEMAC » Fri Oct 26, 2018 1:19 pm
Hello there,
I got a problem with my utcomp Pro. I'm using the NTC-temperaturesensor from reveltronics store for oiltemperature measurment. Everytime my temperatur got more than 100°C and drops after that, utcomp displays the "1" in front of the correct temperatur farther till i restart utcomp. The funny thing is, I didn't get this problem with the watertemepratur. On watertemperatur I'm using this NTC-Sensor (https://www.pkwteile.de/vemo/2291866). It only affects on the oiltemperatur.
Picture 1 displays the temperatures above 100°C and the second picture shows the digits after the drop below 100°C.
Is there a bugfix for this problem ?
Display after the drop below 100°C
Above 100°C
Re: Oiltemperatur Digits
Postby ArT » Fri Oct 26, 2018 1:21 pm
Could you export your UTCOMP settings file and share it here (as .zip)? I'll check it.
SEMAC
Postby SEMAC » Fri Oct 26, 2018 1:22 pm
Yes, I'll do it later this day.
Greetings from germany :)
Postby ArT » Fri Oct 26, 2018 1:23 pm
Ok I'll be waiting. Maybe it is bug and update will fix it. Please tell me also your firmware version. Thanks and greetings from Poland 8-)
SEMAC
Postby SEMAC » Tue Nov 06, 2018 8:30 pm
Hello Art,
Sorry I was too busy the last days. Here is the zipped export file.
Firmware is V3.6.0
Best regards
Max
UTCOMP_v3-6_settings_2018-11-5_2031121.zip
(4.7 KiB) Downloaded 979 times
Postby ArT » Wed Nov 07, 2018 11:11 am
Hi Max,
Thank you for sharing it. You are right and I found the bug. You are using OLED screen in "upside down" mode and it happens only in this mode (in standard mode is ok). We are going to fix it (I'll share you update with fixes). Keep in touch!
BR
Artur
Postby ArT » Wed Nov 07, 2018 2:58 pm
Dear Max,
Please check your PM. Just sent you update with fix. Please check it.
BR
Artur
