OLED display dimmer at night
g300d
Has thanked: 4 times
Postby g300d » Fri Nov 30, 2018 12:43 am
Does UTCOMP PRO have a dim display function when the vehicle lights are switched on?
I did not find reference in the online manuals or any input in UTCOMP PRO harness for illumination that can activate a dim function.
Re: OLED display dimmer at night
Postby ArT » Fri Nov 30, 2018 8:04 am
Yes it has based on pin A21 (it is shared with cooler input so you should pick up one: cooler input or headlights input)
Next in settings -> Display -> Dimmer set enable. And then you can set 2 brightness mode (it will switch when headlights are switched)
g300d
Postby g300d » Fri Nov 30, 2018 2:18 pm
I see, I misunderstood and thought that was an output, not input.
Thank you for clarifying!
