Hall Effect Sensor install
DArtagnon
Postby DArtagnon » Wed Jan 23, 2019 12:48 am
Can anyone share pics of the hall effect sensor install on a motor? How close do the magnet and sensor need to be?
Matthew
Re: Hall Effect Sensor install
Postby ArT » Thu Jan 24, 2019 11:08 am
Usually 1-3mm is fine. Please take a look for short manual for connection diagram:
https://www.reveltronics.com/downloads/ ... E4905L.pdf
DArtagnon
Postby DArtagnon » Fri Jan 25, 2019 4:15 pm
Do you know if there is a limit to how quickly the sensor can track? For vehicle speed, I'm considering mounting the magnets on the drive shaft, which has a ~5" diameter. That means it will be spinning pretty fast, around 3,500 RPM @ 60mph. If I put on 2 magnets, that would be 7,000 RPM @ 60mph, which is around 116 hits/sec if I did all my math right.
Matthew
DArtagnon
Postby DArtagnon » Sun Jan 27, 2019 12:40 am
I've switched gears... found a mechanical to electrical adapter, which will be much easier, as long as it works.
https://www.ebay.com/itm/222373773614
Postby ArT » Mon Jan 28, 2019 1:03 pm
It's fine.
This adapter looks fine too and will work. If you have place for it :-)
