Utcomp Pro forgets date
Horst
Postby Horst » Sat Apr 13, 2019 2:54 pm
My Utomp Pro forgets the date after the ignition has been turned off.
I set the date to: 13.04.2019 , 14:40 -> turn off -> turn on and the date jumps up to 01.01.2019 , 00:00
I have tried it several times but it does not work.
The service reminder and the traveled distance etc are displayed correctly. So i dont know whats the problem.
What could it be?
Re: Utcomp Pro forgets date
Postby ArT » Mon Apr 15, 2019 1:23 pm
The problem is that you do not have connected constant +12V at pin A24. When you switch off ignition you should still have +12V at pin A24.
The other reason may be in settings (Settings -> preferences -> standbymode) - if you want to use clock you should select "power-safe" mode (NOT ultra power-safe where watch is disabled).
Horst
Postby Horst » Mon Apr 15, 2019 4:01 pm
Yes the "ultra power save" mode was my fault. Thanks a lot :)
