Help for UTCOMP installation in a Merdedes C280 1995
bravisimo
Postby bravisimo » Mon Feb 17, 2020 3:37 pm
I want to buy UTCOMP-3, but before I need to know if my car has got all the wires needed to do it.
My car is a Mercedes Benz C280 Petrol Automatic (6L cylinders)1995'.
I will only need the following gauges:
Current L/100 Km
Average L/100 Km
Distance to empy in KM
I know that the RPM and Fuel level wires are in a swith at the back of the Dashboard, but I don't know if that signal are the ones that UTCOMP requires.
I don't know what wire (and where is it), for the fuel inyectors.
Regards,
Antonio
Re: Help for UTCOMP installation in a Merdedes C280 1995
Postby ArT » Tue Feb 18, 2020 10:47 am
Hi Antonio,
Speed signal you can get from speed sensor (X91) or abs module (A16) - it's green white wire which is going to instrument cluster at pin M2:
2020-02-18 104142.png (204.75 KiB) Viewed 9542 times
Injector signal (for fuel consumption) you can get from any of injectors (directly) or any pin in ECU pin 23 or 13 or 2 or 3 or 12 or 24 socket 2:
2020-02-18 104319.png (82.72 KiB) Viewed 9542 times
2020-02-18 104412.png (127.38 KiB) Viewed 9542 times
bravisimo
Postby bravisimo » Tue Feb 18, 2020 3:29 pm
Hello Art,
Many thanks for your answer.
My last question, what about fuel level, can I take the signal from the instrument cluster?
Thanks in advance,
Regards,
Antonio
Postby ArT » Tue Feb 18, 2020 3:41 pm
Don't know what type of signal is it, if it's 0-5V voltage signal then yes.
But you can also measure fuel level from consumption (it's by default) - you do not need to connect any additional signal in such case.
bravisimo
Postby bravisimo » Wed Feb 19, 2020 8:41 am
Hello Art,
So, the UTCOMP can show me the Distance to empty automatically, with the current fuel consumption and the distance, is it?
Is it necessary to introduce each time I fill the petrol tank?
Regards,
Antonio
Postby ArT » Wed Feb 19, 2020 9:39 am
Yes it can show you, but every refuel you need to reset stats. If you refuel to full it's quick and easy, but if you refuel to not full you will need to provide amount of liters.
