UTCOMP-3 and UTCOMP-PRO
Postby ArT » Wed Mar 25, 2015 6:55 pm
Latest comparison UTCOMP-3 vs. UTCOMP-PRO - check it here
Some of you already know (from various sources ;) )that we are working on new versions of UTCOMP-3 (version 3.0) and UTCOMP-PRO. It should be available in the second half of April. Now I'm giving you few information about new modules.
edit: UTCOMP-3 and UTCOMP-PRO are available since 22th April '15
General info:
  • UTCOMP-3 is the successor of UTCOMP 2.5,
  • UTCOMP-PRO is more advanced version of UTCOMP,
  • UTCOMP is compatible with LCD 2,5" and OLED 2,3" displays - both 122x32 pix,
  • UTCOMP-PRO is compatible with OLED 3,2" 256x64pix display,
  • UTCOMP-PRO has more inputs and supports more sensors,
Main differences between UTCOMP-3 and UTCOMP 2.5:
  • new module is compatible also with 24V installation,
  • less current consumption (energy saving),
  • LCD contrast adjust on the buttons,
  • pinout compatible with 2.5 version,
  • display compatible with 2.5 version,
  • more possibilities of input configuration, e.g. there is possibility to use additional resistance/NTC sensor (with power supply from UTCOMP) and connect to factory one as well (buffered input),
  • possibility to assign temperatures to sensors, e.g. engine/oil temperature can be measured from digital or analog sensors,
  • additional pressure measurement (e.g. there is possibility to measure boost pressure and oil pressure at the same time),
  • additional alerts (all temperatures, voltage, turbo pressure, oil pressure, AFR, EGT, fuel level, speed limit),
  • analog inputs can be labeled on oscilloscope.
Main differences between UTCOMP-PRO and UTCOMP-3:
  • bigger OLED display with higher resolution available in 4 colours,
  • 5 more analog inputs (total 7),
  • 2 more digital temperature sensors DS18B20 (total 4)
  • additional digital input (e.g. for RPM),
  • additional digital output (e.g. relay control 5V/100mA) - reserved for future use and custom firmwares,
  • additional external FLASH memory (user can change OLED graphics, data-logger),
  • data-logger - recording up to 10 parameters,
  • new 16-pin display connector (longer tape possible),
  • 3 additional configurable user screens with new templates (total 4 user screens).
Pictures:
UTCOMP-3 vs UTCOMP-PRO
OLED 3,2" for UTCOMP-PRO
OLED 2,3" (UTCOMP) vs OLED 3,2" (UTCOMP-PRO)
minitruck
Re: UTCOMP-3 and UTCOMP-PRO
Postby minitruck » Sun Mar 29, 2015 4:55 pm
damn, that looks very nice!
maybe I should have waited ordering mine, because I just ordered today... :x
Postby ArT » Sun Mar 29, 2015 6:11 pm
Please check your PM, just sent you one.
logkeeper
Contact:
Postby logkeeper » Tue Mar 31, 2015 7:27 pm
Great news.
I think to buy version 2.5
Now wait for the release of version 3, or MDP
Estimated cost?
Thank U
Postby ArT » Tue Mar 31, 2015 8:22 pm
~80 EUR for UTCOMP-3 LCD 2,5",
~110 EUR for UTCOMP-3 OLED 2,3",
~160 EUR for UTCOMP-PRO (OLED 3,2")
Prices may slighty change due to exchange rate.
UTCOMP 2.5 will be still in the offer (~65 EUR).
We will share info at our page and at facebook - propably in 2-3 weeks.
logkeeper
Contact:
Postby logkeeper » Tue Mar 31, 2015 8:28 pm
UTCOMP-3 OLED 3,2 "how much can it cost?
160 euros I think expensive
But wait the final price
Later, ask questions about the connections.
Thank U
Postby ArT » Tue Mar 31, 2015 8:32 pm
Yep, OLED 3,2" is quite expensive on the market but it's awesome display.
We will share user manual for UTCOMP-PRO in few days.
Generally, main 24-pin socket is the same in all UTCOMPs.
logkeeper
Contact:
Postby logkeeper » Tue Mar 31, 2015 8:34 pm
ok
I will wait.
logkeeper
Contact:
Postby logkeeper » Tue Apr 21, 2015 6:25 pm
Good day.
What news?
Postby ArT » Wed Apr 22, 2015 10:53 am
New UTCOMP-3 and UTCOMP-PRO are available starting today :mrgreen:
